Spur gearbox vs Planetary
Hello All,
I am looking for a white paper (searched here and did not find) on the subject of pros and cons of Planetary gearboxes over Spur gearboxes.
Does anyone here have an idea where I could find such an animal?
I thank you all for your time and efforts
Fritz
Fritz
RE: Spur gearbox vs Planetary
Machinerys Handbook or Dudley's Practical Gear Design will tell you what you need to know about the basics of spur and planetary gear trains.
I don't know what your application is but I would suggest sticking to spur gears. A few things to note about the two:
-Spur gears are a little less complicated to manufacture and package than a planetary.
-A simple planetary is somewhat limited in ratio with a single stage, compared to a single spur mesh.
-A single planetary stage will give you a coaxial input/output; A single spur mesh will give an offset input/output.
-A planetary gear set will be a bit lighter than a spur gear set for a given shaft torque.
Good luck.
terry
