Double Interpolation of Tabular Data
In Excel, I have a table of data giving fluid densities (rho) with temperatures (T) and pressures (P) as parameters. In other words, my table looks like this:
DENSITY vs. T,P
P1 T1 Rho1,1
T2 Rho1,2
T3 Rho1,3
P2 T1 Rho2,1
T2 Rho2,2
T3 Rho2,3
etc.
My problem is that I want to estimate the densities at in between values of temperature and pressure and to use the estimated values in subsequent calculations. I could probably do it if I had a single interpolation, but it's looking extremely awkward. Anyone have a solution to this? (I'd prefer a non-VBA solution but would gladly accept anything that works.) Thanx.
DENSITY vs. T,P
P1 T1 Rho1,1
T2 Rho1,2
T3 Rho1,3
P2 T1 Rho2,1
T2 Rho2,2
T3 Rho2,3
etc.
RE: Double Interpolation of Tabular Data
If you were to graph your table you would have pressure on the X axis, Density on the Y axis and have three curves for temperature.
Imagine you want the density at P1.5, T1.5
You would enter your graph at P=1.5 on the X axis, go up to the T=1 curve and put a big black dot there. Then you would go up to the T=2 curve and put a dot there. Then you would draw a line between the two dots.
Next you would say, ok, T=1.5 is half way along that line.
So do your interpolation like you would if you were looking at the graph.
the excel file make a first linear interpolation on pressure and a second linear interpolation on temperature.
Should be better developed for upper bound, because now when p=pmax or t=tmax there is an error.
On C2 and C3 you should input the desired Pressure and temperature.
On A25:C37 there is the table.
Hope this help!
Onda
For steam tables you can download a free excel add-in from http://www.cheresources.com/iapwsif97.shtml.
Also look here http://www.techwareeng.com/products.htm for steam tables and an excel interpolation functions (I have not used these).
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
h
It includes one and two way interpolation functions (linear and logarithmic) as well as a number of functions for finding intersection points, and rotating and translating coordinates.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Dik
Greg, can you provide a link or otherwise tell us how to get to this add-in. Thanks.
http://www.xlxtrfun.com/XlXtrFun/XlXtrFun.htm
Cheers
Greg Locock
I wrote myself a VBA code
Function lin_interp(x, x1, y1, x2, y2)
lin_interp = (x - x1) / (x2 - x1) * (y2 - y1) + y1
End Function
This will give you a one-way linear interpolation if you like. So now you can apply this equation as many times as necessary to interpolate your in-between values.
For example, you know P1, P2, T1, T2, rho1, rho2 and you want to calculate rho at P1.5 and T1.5. You first run your linear interpolation to find the intermediate rho value at P1.5 and T1:
lin_interp(P1.5,P1,rho1(at T1),P2,rho2(at T1))
# This will calculate rho at P1.5 and T1.
Then you will need to calculate the intermediate rho value at P1.5 and T2:
lin_interp(P1.5,P1,rho1(at T2),P2,rho2(at T2))
# This will calulate rho at P1.5 and T2.
Now it is simply finding rho at P1.5 and T1.5.
lin_interp(T1.5,T1,rho(P1.5,T1),T2,rho(P1.5,T2)).
I haven't had a chance to look at the other solutions that have been posted but it sounds like they are easier than what I have posted.
-- MechEng2005
so k = P1/(T1p1) and p2 = P1/(kT2)
One does not need a regular mesh.
Each reference point has a weight inversely proportional to its distance to the point where the interpolation is desired.
Mathematically It's not very smart, and the method has serious drawbacks. Practically it works fine for most engineering work. Do not extrapolate.
PLease find an Excel spreadsheet.
htt
Brian
