english units system for FEA analysis
Hi
Actually I am using the following system of units for my FEA simulations.
length: in
force: lbf
Elastic Modulus: psi
mass: lbf
mass density: lbf/in^3
WTMASS Param: 0.00259 ( why do I have to set up this parameter?)
Acceleration (1G): 386.1 in/sec^2
OUTPUT
Disp: in
Force: lbf
Stress: psi
I am used to carry out my FEA simulation with the metric one, but my customer wants the output in imperial units, therefore I started use the above systems.
I heard that there are different english systems of units for structural analysis, is the above one consistent?
What is the most english systems of units for structural analysis?
thanks
Engroma
length: in
force: lbf
mass: lbf
OUTPUT
Disp: in
Force: lbf
Stress: psi
thanks
Engroma
RE: english units system for FEA analysis
Personally I "always" work in SI units.
But since you ask, there is a site at NASA that gives some unit "systems:
http://femci.gsfc.nasa.gov/units/index.html
I'm not sure what you need but it might help.
Good Luck
/Thomas
