Structural Tubing Telescopic Connection
Two pieces of tubular steel sections (round or square or rectangular) are telescopically connected as shown on the attached sketch. How to calculate/determine minimum overlapping length in order to develop full moment capacity of the smaller section?
Thank you,
IV
Thank you,
IV
RE: Structural Tubing Telescopic Connection
i'd anticipate bolts; a minimum of two rows would produce a reasonable bending connection.
how tightly do the two pieces fit together ?
obviously, if there is a lot of clearance, the two pieces will act more like a plastic hinge.
Dik
1. Calculate Moment capacity of smaller section = SxFb
2. Calculate a couple equal to M/d where d = overlap length
3. Calculate shear strees equal to Couple/Av where Couple equals M/d & Av equals shear area in vertical legs
4. Check shear stress against allowable
5. Recalculate overlap length and repeat until shear stress is less than allowable.
This analysis assumes a tight fit between the pieces.
