Enclosure Latches UL508/CE
Does a UL508 listed or CE safety marked control panel require the enclosure to only be opened with a special tool (screw driver) etc. I have a customer who is requesting to have screws added to a standard fiberglass enclosure that currently only has latches. This is what they have always done but they are not sure why.
RE: Enclosure Latches UL508/CE
UL 508 does not require the enclosure to be opened with a special tool. In fact, the standard actually mentions latches to be a valid option, as long as they remain attached to the enclosure when the door is opened.
I can't answer your question for CE.
Caspar
If there is no disconnect, then the panel needs to be secured to where a tool is required to open it. So, If your latches can be undone by hand, then yes you need to add screw-downs. I'm not sure, but maybe adding a padlock clasp would help.
