specific gravity
specific gravity
Sorry for this stupid question. What is specific gravity? What is the physical meaning if a fluid has a specific gravity of 0.835 Max at 15 deg Celcius?
RE: specific gravity
The max likely means that the fluid's density varies somewhat (like for diesel which is a mixture of different hydrocarbons) but won't exceed 835 kg/m3.
Specific Gravity is,
The ratio of the weight of anything to the weight of water.
For example
water is 8.34lbs/gal
its specific gravity is 1.
HCL is 10.0 lbs/gal
Specific Gravity of HCl = Weight of HCl (/) Weight of Water = 10.0 (/) 8.34 = 1.2
ain't it specific weight?
Truth: Even the hardest of the problems will have atleast one simple solution. Mine may not be one.
For a gas, it's almost always the ratio of the gas's molecular weight to air (I use 28.96) but I've seen it sometimes referenced as the density of the gas at its temperature and pressure divided by the density of air at the same temperature and pressure. The latter is much less common in my experience.
