Need help to calculate VOl fraction
Hi every body
I have an elementary question because i am confusing now.
I should prepare different mixtures of powders for sintering. the instruction gave me the fraction of element in mass percent but i want to have one of the compund in the mixture in Vol%. let me to write one of the mixture here:
Fe-0.8Wt%C-0.15Wt%B this is the mixture that I want to add 10 vol& of tungstencarbide. how can I calculate the amount of each constituent in gram?
i will be appreciated if some body can help me.
Thanks in advance
Thanks in advance
RE: Need help to calculate VOl fraction
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
This can be reduced to an equation but I never bother to memorize it. It helps to reduce errors when you understand what you are doing.
Cory
