NX6 Drafting: how to align notes both Vertically and Horizontally
NX6.0.1.5 MP1
I'd like to be able to have a Note snap-aligned in both the horizontal and vertical directions (ie to two other notes). I can only seem to get the note to "rubber-band" in one direction at a time.
Is there a way to accomplish what I'm trying to do? Or is one stuck "getting it close" by eye?
Incidentally what I'm actually trying to do is to set up default text in a drawing template, so I'm trying to get text aligned in the boxes on the drawing.
RE: NX6 Drafting: how to align notes both Vertically and Horizontally
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
rmc text > origin > point constructor (right icon) > change lightening bolt to control point
The alignment position of the text is very important. For most places on the title block I use "middle center" so that the text stays centered in that box when it grows or shrinks - so therefore is no need to associate it to anything (other text).
I do use "middle left" as the alignment position for a couple other things (such as the Description of the drawing) so that start of the text is always at a certain point and it grows to the right.
rmc text > style > alignment position (top right icon)
Unless you're particularly fussy about the alignment this setting will aid in getting it quite close by eye.
Cheers
Hudson
Just wanted to say thanks for the useful tips. However, rather than deleting the construction lines, I just put them on their own hidden layer.
