Dimension conversion
From my tech.
"I did a new drawing using mm. I tried to change it to just inches, but so far can only get dual dimensions on existing dimensions. There are a lot of them, so if you know of a short-cut way to change all the existing mm dimensions to inches"
We have templates but it seems he has the drawing already done in mm and the engineer he is working with needs a conversion to inches. TIA
RE: Dimension conversion
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Follow me on Twitter
