Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have found your site brilliant. What makes it good are the people that contribute to the site..."
Geography
pcomp (Mechanical)
5 Jan 09 13:51
Appreciate, if some one recomends good text editors (freeware) for Nastran deck. I had one good flexible text editor, that highlights all nastran keywords and wors well with huge text files. But I forget the name now. If any one has one, please recommed me.
Helpful Member!  Onda (Marine/Ocean)
5 Jan 09 15:13
I use VIM http://www.vim.org/. it's freeware. you can download the Nerd commenter http://www.vim.org/scripts/script.php?script_id=1218 for highligthing.
Much easier is ultradit-32 but it charge some money.  http://www.ultraedit.com/, you can download the wordfile from http://www.ultraedit.com/downloads/extras.html.
regards
SWComposites (Aerospace)
5 Jan 09 15:43
UltraEdit.  Works great on large files; very fast.  Very good copy/cut/paste - can even select a block of text (columns x rows) rather than whole rows.  Well worth the cost.
39minuteman (Aeronautics)
24 Feb 09 15:11
You could try Notepad++. It's free and I can give you file with Nastran highlighting scheme for it. It works well.
http://notepad-plus.sourceforge.net/uk/site.htm
truckcab (Automotive)
3 Mar 09 14:06
Download cygwin (free), then you can use Nedit. Cygwin is great for many other reasons too... Recommend it.
awk, sed, Perl etc.
Live Long and Prosper !
keith972 (Marine/Ocean)
9 Mar 09 16:44
Hi 39minuteman,
I am a naval engineer new user of Nastran.
I installed notepad++. Can you send me the Nastran highlighting scheme for it, please?
Thanx
GregLocock (Automotive)
11 Jun 09 0:00
crimson editor, and editpad, are both free stable and powerful text teditors for windows, crimson editor being my preferred one. winmerge or csdiff are good for doing diffs on decks, winmerge is prettier, csdiff will create a machine readable differences file.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
kellnerp (Mechanical)
2 Jul 09 9:34
Ultraedit
TOP
CSWP
BSSE
www.engtran.com
www.niswug.org
"Node news is good news."
CRapaci (Structural)
4 Jul 09 8:52
I use PFE (Programmer's File Editor), it is very simple and intuitive to use. You can use create and run macros very easily. The disadvantage is the absense of a color scheme, or the capability of select columns... this make me sometimes use the crimson ... but indeed I always have used the PFE... I recommend both of FREEWARE programs!
1st - PFE
<http://www.lancs.ac.uk/staff/steveb/cpaap/pfe/pfefiles.htm>
2nd - Crimson
<www.crimsoneditor.com/>
have moderate fun
Celso
knfulcrum (Aerospace)
1 Dec 09 13:06
I use GNU Emacs v 23.1.  Has support for NASTRAN mode.
mariotte (Mechanical)
22 Dec 09 5:58
can anyone send me Notepad++ highlight scheme for Nastran, please?
Thanks.
Mario
Onda (Marine/Ocean)
23 Dec 09 12:57
Hi Mario, I have done a syntax highlighting starting from the ultraedit syntax file. I believe there is no copyright on the syntax file and we can use for other text editor. If I'm wrong, please remove the post!
I attach the file here. let me know if is good for you.
Onda
Zigmhount (Mechanical)
7 Jan 10 8:23
Hi Mario,
here is my highlight scheme for DAT and f06 files (and PRG for Femap Program Files).
Let me know if you extend it.
nimbusbs (Aeronautics)
23 Mar 10 6:29
Hi Onda,
if tried your highlighting scheme, but in my case it doesn't work with the current version of notepad++ (it always breaks down).
@Mario: Is it working for you?
I'm searching for a scheme which is able to highlight every 8 columns of the .bdf file, so that you can easily read through the bulk entries. It's really was really enoying the first time with the windows editor.
Thanks in advance,
Heiko
PaulBlelloch (Aerospace)
23 Mar 10 19:59
I would like to try out the notepad++ style sheets, but don't know where to place that file.  Can anyone tell me where to place the .xml file?
24 Mar 10 5:10
Hi Paul,
I'm using the current 5.6.8 version of notpad++. There you can usally go on "setup" ("Einstellungen" in the german version), then click "import" and "themes". There you select the file. Afterwards you load this theme in "setup" -> "style".
But I've to admitt it doesn't work in my case. If anyone did manage to use the style-scheme....
Onda (Marine/Ocean)
24 Mar 10 5:54
Hi Paul,
I've read a lot of your interesting posts on VPD community.
In my computer the XML file is in the installation directory of notepad++ : C:\Program Files (x86)\Notepad++. (OS XP X64)
To keep the file in that location, during the installation you should check the box with the following text: "Don't use %APPDATA%"
Onda
24 Mar 10 6:16
if reinstalled it the way you recommend: Now it worked. Everything looks very eyecatching except the 8 letters whide columns:
BEGIN BULK
$ Direct Text Input for Bulk Data
PARAM    POST    0
PARAM   PRTMAXIM YES
$ Elements and Element Properties for region : pshell.87967217
PSHELL  87967217 1      .7
$ Pset: "pshell.87967217" will be imported as: "pshell.87967217"
CQUAD4  153411028796721715443877 3007    2975   15443894 0.
CQUAD4  1534110387967217 2975    2946   1544389115443894 0.
CQUAD4  153411048796721715443878154438771544389415443895 0.
CQUAD4  153411058796721715443894154438911544389015443895 0.
CQUAD4  153411068796721715443879154438781544389515443896 0.
CQUAD4  153411078796721715443889154438961544389515443890 0.
CQUAD4  153411088796721715443880154438791544389615443897 0.
CQUAD4  153411098796721715443896154438891544388815443897 0.
CQUAD4  1534214687967217 3020    3007   1544387715443911 0.
CQUAD4  153421478796721715443878154439121544391115443877 0.
CQUAD4  153421488796721715443912154438781544387915443913 0.
CQUAD4  153421498796721715443913154438791544388015443914 0.
Isn't there someone having the same problem that you can't see to which field the entries belong to?
Onda (Marine/Ocean)
24 Mar 10 9:38
@ Nimbusbs
You could set one vertical line to check a field length.
to do this go under Configuration>Preferences>Editing>Vertical edge setting
Check the box for Show vertical edge
set a number multiplier of 8
24 Mar 10 9:51
Thank you Onda! Another method I thought about is to let Patran write the .bdf-file with entries sorted by comma:
CQUAD4,15342149,87967217,15443913,15443879,15443880,15443914, 0.
 Nastran would except that. But I didn't find an option yet...
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
