Long saving with NX6
Following problem NX6
When saving local or network gives a big time difference.
Solution of nltac, "full control need to be set for the users of NX"
We made this changes and solved the problem, later the admin changed the procedure  for the whole directory "I" (our Cad data), unfortunate but the problem is back.
Question, do we need  Full control to be set on every user separately, or is there a different way to speed up the saving time.
Question, have anyone the same problem, and which was the solution ore changes he made
We work with standalone station ( we don't use program team center)
Many thanks
I'am looking forward for this problem
RE: Long saving with NX6
You must resign! For now NX6 is much slower NX4.
All tests in each application unfortunately confirm this.
We hope that soon this problem is resolved.
Ciao.
If the difference in save times depends on whether you're connected locally or over the net can NOT be blamed on the performance of NX 6.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I did some testing before, and with...
Nx5 locally and network // Same speed
Nx3 locally and network // Same speed
Nx6 locally // Same speed
Nx6 Network // Very slow (not workable)
Nltac says that NX6 works different with a network.
Thats why I put the questions online, I think NX6 needs some precise settings. in the windows network environment.
regards
