Full killed carbon steel and Sour...
Dear sir
I'd like to your explain these item below.
1. Full killed carbon steel
2. killed cabon steel
3. sour service H2s
4. Cs+NACE MR0175
RE: Full killed carbon steel and Sour...
Killed Carbon Steel is a process of deoxidation that is performed during the steel making process. Normally, ASME B&PV Code requires steels that have 0.24% or greater carbon contents to be killed (fully de-oxidized) using either Al or Si additions, and especially those steels that fall under a forging grade.
For sour service and NACE MR0175 go to
http://www.genel-makina.com/2008/pdf/bulten1155.pdf
lm
