MAP & MAWP
MAP & MAWP
Hi !!
Can some one please tell me the real logic why MAP & MAWP are always calculated at the top of the vessel???
RE: MAP & MAWP
Joe Tank
RE: MAP & MAWP
"By using the top of the vessel it is absolutly clear that it is a pressure applied from an external source."
creates some confusion because as far as i know it is the pressure calculated against the actual governing pressure and is used for re rating the vessel .. Please could u elaborate these two points.
BR
RE: MAP & MAWP
Joe Tank
