Designing parametric Spur Gear (Tutorial Video)
Hi everyone.
Finally, I made a parametric spur gear on NX and decided to create a tutorial. I hope this would be useful for you.
First, download and install TechSmith Screen Capture Codec:
CODE
http://download.techsmith.com/tscc/tscc.exe
Then download the following files and extract them via WinRAR into a folder:
CODE
http://ifile.it/gel5b3v
CODE
http://ifile.it/m2p7okd
Remember, before you try, set your NX Roles to Advanced with full menus. By the way, in order to better understanding review the parameters comment in Expression dialog box.
Any question and suggestion would be appreciated...
Good luck.
