TEMPERATURE FOR FULL VACUUM DESIGN
Hello all and happy new year,
In designing shell and tube heat exchangers (which are considered pressure vessels, so the question refers also to pressure vessels): what are the criterias or guidelines or rules for specifying the temperature at which full vacuum design mechanical calculation will be performed?
regards,
roker
regards,
roker
RE: TEMPERATURE FOR FULL VACUUM DESIGN
Only the process engineer can establish whether a vacuum condition exists for the vessel with the associated temperature.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
