Settlement calculation using Excel spreadsheet
I am looking for spreadsheet programs to calculate soil settlement. Is there anyone has spent your valuable time and effort to develop such programs?
RE: Settlement calculation using Excel spreadsheet
You have to be able to say-"It can't be right" or "Makes sense"
Using spreadsheets by others, also will make you copy their built in errors without knowing it. Besides, for computing stresses, did the spreadsheet designer use Westergaard or Bousinnesq? What about if you have layered soils or crust over soft subsoils-are those spreadsheets still applicable? Try longhand and then develop your own later.
but it is nice once you've developed on that can do calcs for several different locations based on the condition you set up. i've found that even with a well developed spreadsheet, you often must make minor adjustments to the spreadsheet for something specific to the job. but once it's set up for the project and checks out with a few hand calcs, you can quickly evaluate several different scenarios.
P.W. Mayne and H.G. Poulos, Approximate displacement influence factors for elastic shallow foundations, ASCE J Geotech Geoenviron Eng 125 (1999) (6),
You can compute this Index by using lab consolidation tests as usual, or you can use the Hough chart relating this index to blow count for different soil types Of course assumptions along the way may be rough.
I note that the LRFD design manuals use the Hough method as part of their procedures. I believe the Ohio DOT has adopted it also.
Unfortunately his original paper back in 1959 (ASCE SM4 Journal #2135)"Compressibility as the Basis for Soil Bearing Value" is not in any available WEB site that I know of.
His text book :"Basic Soil engineering" also is out of print.
In general if has been found the chart relating to blow count results in conservative settlement results by a factor of 2.
