bend line notes
bend line notes
I'm sure this has been covered before but I just can't find it with a search.
I have a very simple lofted bend sheet metal part. it is a transition from a rectangle to a circle almost identical to the tutorial but with different dimensions. 200x90mm rectangle with 5mm radius corners split in the middle of one short side. the hole is made up of 4 arks 21mm radius and 4 1.5mm straight lines. 3 bends on each section.
I have a flat pattern with bend lines however it will not give bend notes with the angles. I have the "display bend notes" checked but nothing happens. the bends are labeled with "freeform bend" which may be causing the problem?
RE: bend line notes
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
