can u start 4 motor w one timer in seq?
I was asked by a workmet, he said can there be a control circuit to start may motors in sequence using one timer? i am thinking but u may aid me.
Vitzwates RSA
Vitzwates RSA
RE: can u start 4 motor w one timer in seq?
If it's a challenge, it will depend on the timer in question. The term "timer" is far to vague to be of use in this discussion. For example, if you have what is called a "Repeat Cycle" timer, no problem at all. Even if you have a plain old On-Delay timer, you can do it with other relays for logic.
If this is a real application, forgo the timer and do t with a Programmable Relay. They cost about the same as many sophisticated timers and can do so much more.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
vitzwaters
