Metal Roof Waterproof Materials
I would like to learn more about metal deck roof with waterproof material construction details. I am wondering if some one here can give me suggestions or references. Thanks.
RE: Metal Roof Waterproof Materials
Don Phillips
http://worthingtonengineering.com
If you are looking for information on metal roof panels that will serve as the waterproofing system for the building, you can consult many of the panel manufacturers (Fabral, Butler, others) as well as the National Association of Architectural Metal Manufacturers (for finishes) and the Metal Roofing Alliance (http://www.metalroofing.com/)for further information.
It's reasonably involved.
Thank you again and Happy New Year.
Stick to around 5 feet for the spans.
We will use 9' oc span (we use WF beam instead of barjoist), the clear span will be around 8'. Beside the welding (metal deck weld to WF) and metal deck deflection, what other problems I need to concern according to your experiences? Thank again.
