arithmatic operations with autocad fields
i have two mtexts, each has a field. i want to have a third mtext which would be field 1+ field 2. is that possible? i looked around and found some postings about "arithmetic functions in autocad fields" where they say FIELD>ALL>EXPRESSION to do it. i cannot seem to find 'EXPRESSION' in the ALL category. i am running 2009. am i missing something?
RE: arithmatic operations with autocad fields
Insert Field Formula Sum ??
true, but looks like that only works for tables. my labels are scattered around mtexts. any other ideas?
A diesel expression may work - I'll look into that but I'm skeptical.
What do you mean with mtexts having fields?
a mtext with text like "Area = ****" where **** is an inserted field as INSERT FIELD>OBJECT>AREA. you can get it from the right click menu when you are in the text editor. hope that explains your question chicopee
thanks for the valuable tip Vladimir! that's EXACTLY what i was looking for.
This is similar to geometric calculations insofar as the math expressions that can be used.
Which ACAD version did FIELD first appear?
