equation help!
equation help!
equation help!
I have an equation for the ratio of belt tensions on a V belt at limiting value of dry friction. this is;
T1/T2 = e ^ u * theater/sin angle
would this angle be stated in radians or degrees?
Any help appreciated Im not an automotive engineer (im structural) and this is a theoretical questions ive been asked ands although ive said its not my field its bugging me. It cant be degrees as you wont get a solution but all the data is given in degrees. Should this be converted to radians or is the formula incorrect.
thanks again.
RE: equation help!
Any equation without units conversion knobs must be in a consistent unit set.  So I'd expect radians.
- Steve
RE: equation help!
It's e to the (mu*theta).  Where e=2.718, mu = coeff. of friction and theta is the angle of wrap in radians (1/2 wrap = 3.14 radians)
RE: equation help!
cheers guys Ill pass the info on and sleep easy. thanks again.
