Trying to make a DWG into a readable GIF
Hello all,
I am currently trying to export a DWG file into a GIF, I have tried the exporting to a BMP but the words on the drawing ended up as solid shapes..
Any help would be appreciated.. Thanks
RE: Trying to make a DWG into a readable GIF
I have had a similar problem when trying to convert to a PDF.  If the text had a text mask on it, it would show up as solid.  If possible, try to remove your text masks and that might do it.
http://www.autodwg.com/DWG2Image/
here you have the right thing that you are looking for, this application convert drawings into bitmap with crystal clear quality, it is recommended to run the AutoDWG program and select GIF for the output file format, and 300DPI resolution, image looks great and file size is comparable smaller.
