Solid not displaying right in drawing.
I made a solid, put a bunch of holes on it, then put it on a drawing but the outline is not showing. only the holes.
Any idea what could be causing this? Nothing special about this part, just a bunch of extrudes and cuts.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
RE: Solid not displaying right in drawing.
Did you drag and drop only the hole features into the dwg?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Has the outline Line Format colour been changed, or somehow been hidden?
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Subwoofer: I havent noticed this with cosmetic threads but maybe because I dont require cosmetic threads in drawings.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Try this: FAQ559-1058: How do I set the Software OpenGL option in SW and turn the Hardware Acceleration to "None"?
This is a long shot...Activate the view with the problem...in the line format toolbar toggle the color display mode...see if this fixes the problem.
Jorge
Mechanical Engineer
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
