Is ANSI B5.38 valid for all ratchet tools?
Hi Folks
I am designing an adapter that on 1 end requires a standard male 3/8" socket (standard working rachet sockets and extensions).
I am looiking at the Machinery's Handbook and see on page 949 (Edition 27) the dimensions for "American Standard Square Drives for Portable and Electric Tools ASA B5.38-1958)
I assume this is applicable to the square ends found on standard sockets and extensions
Jay
pcb4u AT verizon DOT net
RE: Is ANSI B5.38 valid for all ratchet tools?
It does.
Ted
Thanks so much...being an electrical engineer, this world of mechanical "stuff" can be confusing...
Jay
You might want to look at a Lowell Wrench, the old name, or ratchet arm as they give a lot more options as far as size goes.
http://www.lowellcorp.com/
I'm looking for the dimensions for the male end of a 3/8" extension (width, depth, ball detent setback, etc). I believe the data I found appears to be the data for standard sockets and extensions (male and female sides)
Jay
