Creating PDF files from AutoCAD R14 with Adobe Acrobat 6.0
We have a large number of old AutoCAD R14 drawings. We need to create PDF files of many of these.
If I open one of these drawings in AutoCAD, tell it to print, and select as a printer "Adobe PDF", I get a single page PDF file (either with just one page of the drawing or with all the pages of the drawing shrunk to fit on a single page of the PDF file).
If I attempt to open one of these drawings in Adobe Acrobat 6.0 Professional, I get an error message. I called Adobe and was told that although Adobe Acrobat 6.0 Professional says it can open AutoCAD drawings, it can only do so on computers with one of certain more recent versions of AutoCAD installed; it cannot do so on computers with AutoCAD R14 and no other version.
Our current method is to first use AutoCAD R14 to create separate PDF files of each page, one at a time, and then use Adobe Acrobat 6.0 Professional to combine the separate PDFs of the different pages into a single, multipage PDF.
This process takes more time than creating multipage PDF files of other types of documents (for example, Microsoft Word) because:
1. I need to do each page one at a time, instead of all at once
2. I need to use two programs (AutoCAD and Adobe Acrobat)
Without buying a newer version of AutoCAD, is there
a) a faster way to create multipage PDFs of AutoCAD files
or
b) a way to accomplish the entire process in a single program
or
c) a way to do all the pages at once, instead of one at a time
or
or
RE: Creating PDF files from AutoCAD R14 with Adobe Acrobat 6.0
It did get tiresome for batch drawings. A bigger issue for us was the handling of LINE MERGE. Acrobat and many others (including later Autocad built in PDF writer) did not handle line merge properly. So, we sought a 3rd party solution.
I highly reccomend Acroplot:
http://www.cadzation.com/acroplot_info.htm
