NX4 Operating system size
I am going to be trained to do CNC programming using NX4 and I need to load the operating system onto a laptop. I am buying one specifically for that purpose and I need to know how much memory I need to run it. I have looked at a Dell with a 250 GB hard drive. Will this be sufficient? Thanks for the help, I am a new subscriber.
RE: NX4 Operating system size
However, if you have 250 GB you should be OK. My Dell Laptop only has an 80 GB drive and I've got 9 versions of UG/NX installed on my system (granted only the 2 most recent versions include the user doc's and with some of the older versions, I've removed all but the minimum set of files needed to actually run the software, and I've still got almost 25 GB of free space).
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
When all's said and done any laptop running NX-4 will seldom struggle to run NX-5 or NX-6 and if anything the software has continued to improve. I mention this because CAM is usually an end use that seldom if ever needs to be backward compatible with the design data. The situation being that later versions of NX have no trouble whatsoever reading data from earlier releases it is only when you try to work in the opposite direction that you have trouble. The later versions are better suited to both Vista and 64Bit operating systems and I think cutter path generation does benefit from the added processing power of the latest technology.
For a range of other reasons many experienced users prefer XP over Vista and opt to purchase with what they call an XP downgrade. I purchased from Dell a few months back and was able to get both XP64 and Vista with the downgrade at little or no additional expense. If that option is available to you and you're in a hurry then it would be the one to take so that you're covered either way!
Cheers
Hudson
John R. Baker, P.E.
NX Design
Cypress, CA
Microsoft has given the green light to custom PC manufacturers, allowing them to offer machines with Windows XP
An article posted over on ZDNet.com Sunday reports that Microsoft is allowing system builders--the smaller "white box" builders other than Dell and HP--to obtain copies of Windows XP for preloading on PCs until May 30, 2009. The catch is that all orders for the older OS have to be in place by January 31, 2009 just as Microsoft stated last year. System builders thus take delivery against those orders until May 30, 2009, meaning they don't have to buy the OEM copies in bulk quantities and sit on them, but rather take order of the software more gradually. According to ChannelWeb, distributors and systems builders actually have until December 31 to submit their "XP license demand forecasts" before placing the final order.
This generosity on Microsoft's part seems like a slight nod to the fact that many consumers--and manufacturers in fact--simply don't want Windows Vista. The availability of new PC's with Windows XP should be great news for consumers wanting a new PC without the hassles Windows Vista brings, especially gamers who still boot up older DOS and pre-DirectX 10 games. With gamers having performance issues and software incompatibilities creating havoc with Vista users, many consider Windows XP one of the best operating systems released thus far.
Microsoft officially discontinued Windows XP back in June, cutting off the OS supply to the larger computer manufacturers such as HP, Dell and Alienware. But Microsoft also said that the company would continue to offer XP to the systems builders until July 2009, followed by super-low-cost PC and Laptop manufacturers until 2010. Microsoft will continue to offer support for all the Windows XP platforms (Home, Media Center, and Professional) through 2014.
Is XP favored over Vista? It would seem so, and apparently, the distributors and system builders are really digging the new plan offered by Microsoft. "This should bring relief to the panic buyers and the large online retailers who would have probably bought up inventory in early January," said Ulmen. "I have to commend Microsoft on this channel-friendly strategy."
So what does all this hoopla mean to the end-users? Those looking for a Windows XP computer need not worry, as there will be plenty to hunt down for some time to come. Many distributors trying to avoid Vista hope that this new plan will extend XP availability long enough to expand into Windows 7 when it supposedly ships next year (although its speculated that the new OS could hit the streets as early as mid-2009). As of July 2008, consumers and businesses alike still chose windows XP over Vista.
Cheers
Hudson
So, 2-4gb of memory is probably the sweet spot for your setup.
NX 5.0.3.2 MoldWizard
There is a thing called the /3GB Switch for people with 4GB of memory on an XP32bit system which allows you to maximise the available memory with that configuration. Results may vary from one system to the next but in general you get perhaps a touch over the 3GB mark.
You're best to quickly google the instructions as they're easy to find and should be followed carefully because you're required to edit some system files that it is wise to be cautious to avoid damaging.
Cheers
Hudson
... I've got 9 versions of UG/NX installed on my system
Welcome
I'd like to ask you John, how it's possible, that you can install 9 (probably, different) versions of UG/NX?
Between NX4 and NX5 was change and license server for this two revisons of NX works on different ports (NX4 => 27 000 and NX5/6 => 28 000).
John R. Baker, P.E.
NX Design
Cypress, CA
If the 3GB switch is set, the NX log file contains the line
"Machine supports 3G address space" near the top.
Cheers
Hudson
