Line Heater Sizing
Line Heater Sizing
Line Heater Sizing
Ref Thread:
I am newbie in sizing Line Heater. I went through this thread798-204110: Line Heater Siizng thread which is closed now. I hope there are many of you who size the line heaters using Excel spread sheet or other software's on a regular basis. Any help is greatly appreciated. If anyone has sized it using Promax software, please let me know.
I have the following information:
Gas Flow rate: 6MMSCFD
Oil Flow rate: 120 bbl/d
Preheat Coil Inlet & Outlet Temp.: 60 & 156 deg F
Reheat Coil Inlet & Outlet Temp.: 56 & 80 deg F
Bath Temp.: 185 Deg F
Operating Temp. Preheat: 2500 Psig
Operating Temp. Reheat: 250 Psig
Bath Composition: 50/50 TEG/Water
I appreciate any kind of help...
RE: Line Heater Sizing
Can you get us some more details on oil and gas properties?  Just simulate on Promax - this one would take no time at all.
Thank you Maddocks
Here are Oil & Gas Properties:
Oil:
Specific Gravity = 0.8
Molecular Weight = 170lb/lbmol
Gas:
Components                Mol%
Methane         = 85
Ethane            = 8
Propane        = 5
i-Butane        = 1
n-Butane        =1
I don't know how to incorporate Preheat and Reheat coils together in a single heat exchanger along with Fire Tube.
This is how I have been trying in Promax:
-I put a mixer to mix Gas & Oil and connected the Outlet to the Tube side inlet of first Heat Exchanger
-I connected the Outlet of tube side to a J-T Valve (to reduce pressure)
-Then I connected the Outlet of Shell side (TEG/WATER) to the Inlet of second Heat Exchanger and Outlet of J-T Valve to the Inlet of Tube side.
-So I get my Heat Duty required for both Heat Exchangers.
But I don't know how to decide on No. of PASSES, Required Coil Length, Area Required for both Coils, etc. because I have on them on two separate Heat Exchangers.
Also, how do I size Fire Tube? Please advise me....
Thank you in advance.
Oh man, you're really getting into the details on this one.  Your best bet is to do a multi-block simulation and not worry about the shellside of the heater.  If you really need to get into coil sizing, you should contact a fabrication contractor or a consulting group.  This is a little complex and tends to be a fair amount of trial and error.  For firetube sizing, I usually start with a flux of 10,000 btu/hr ft2 and then adjust slightly to examine my L/D.  You can do the preheat coil as 1 block like you described followed with the reheat block and then just add the duties together for your total heater duty.  Add a fairly good margin like 15-20% to account for some heat losses, calculation issues, and changing conditions.  Installing too small a line heater will be embarrassing.
Thanks Maddocks.
I do the same way how you suggested. Now my concern is Coil sizing. I really need to know this as Line Heater sizing  is going to be part of my job. I need to survive!!!
Thanks again.
here's the answer from the teachers :
the duty is 1.25 MMBTU/hr
The preheat requires 110 ft^2 or 10 17.5 ft passes of 2" sch 80.
The post requires 13 ft^2 or 1 pass of 17.5 ft of 3" sch 80 pipe.
The fire tube is a single 16" U tube of 17' by 2.
Thank you very very much DCASTO.
How did you do this? Did you use any software or spread sheet calculations?
I am using Promax software and I can get the duty but I can't get the Preheat and Reheat coil length, area, passes and size. Also the firetube length. Can you please please let me know?
Thank you in advance....
Hanover, now named Exterran has a program called Quicksize.  The program was mostly based from the charts and data in Smith Equipment's handbook.  Hanover had bough out Smith.
Here is the screen page from a Winsim where I solved the heater flas.  I just typed in the proceedure for the water bath heater
Thank you very much DCASTO for sharing this information. I really appreciate it. Since we have Promax to this do, I have to try with Promax only.
