Reverse load on gear box
What happens if gear box is loaded in reverse direction continuously? Are there any restrictions on load (% of rated load), time (max. time allowed) for reverse loading of the gears?
The GB in question has helical gears and is planetary type gear reduction.
SPM
RE: Reverse load on gear box
Even if you had bothered to tell us which gearbox from which manufacturer, its history, the prime mover, the load, the service factor, the speed, and the enviroment, we would still recommend that you ask your questions of the gearbox manufacturer.
Mike Halloran
Pembroke Pines, FL, USA
smurali1,
Depends on the design of the gearbox.  With single helical gears, driving it backwards will reverse all of the thrust loads on the bearings. And the bearing sets may be designed to carry thrust loads only in one direction.
Some high performance gearboxes have lube jets positioned based on a certain direction of gear rotation.  Some high performance gears are also manufactured with lead correction to compensate for torsional wind-up, and that lead correction is based on the direction of rotation.
You'd best contact the manufacturer to be sure.
