chemicals needed to make tyre softener
Hello all can any body tell me what goes into making a good tyre softener.
It is for a off road large scale 2 wheel drive model car
that i race
that i race
RE: chemicals needed to make tyre softener
http:/
tom
thanks pete
I don't know if anything we use would work for the remote controlled cars you race...? Methylnaphthalene is some real bad stuff and we don't use it no more than we have to...We buy it from kart vendors that are at the tracks we race at....There are prolly 50 other mixes/chemicals that are sold to both soften and add grip....Over here we call it prepping or working tires.
Good luck and check out the links I posted in the thread for more info and a vender that maybe able to help you out.
Brian
NMP = N-methylpyrolidone, boiling point 400F
I have used a plasticizer I found before as prep...It worked well but was not cheap, however it had no voc's which was a characteristic I was looking for. Much safer than the other stuff on the market, for kart tires anyway.
NMP looks promising...Thank you for the tip.
Brian
latters pete
Brian
thanks for the post what is d-limone ???
Brian
