Exploded view problems
Hi. I'm using SW2007 & have a couple of issues with an exploded view.
1 The hatching is staying in the original position on the view even though the components are moved by exploding. I've tried altering, deleting & re hatching etc. but to no avail.
2 Some components in the exploded view are shaded even though I have the plain "hidden Lines Removed" option on. I've tried shading then reversing it but that doesn't work either.
Any ideas & a Happy Christmas to you all.
RE: Exploded view problems
Which card and driver are you using?
GMA 300
Memory size 256MB
Doesn't sound too big does it?
The Driver Version for the card will be shown by double-clicking the card listed.
It says there is no later update.
Cheers
Which card was listed under the Display Adapters?
Happy Christmas
Mick
htt
Make sure your IT guy gets at least an nVidia Quadro FX570 video card and installs the SW approved driver.
Maxing out the RAM wouldn't hurt either, but at least 2GB.
And if you can twist his arm enough, upgrade the processor to the E6400.
Or you could twist both his arms for a new system from http://xicomputer.com/ or similar.
Merry Christmas.
