What does rating 3000,6000,9000 means as per ASME B 16.11
Dear experts,
Can any body suggest what does rating 3000,6000 and 9000 etc. means as per ASME B 16.11. What should test pressure for items produced in rating 9000.
RE: What does rating 3000,6000,9000 means as per ASME B 16.11
test at up to 1.5 x rated pressure
"Pumping systems account for nearly 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Class 2000, 3000, 6000, 9000 are just designations.
Read section 2 and see, especially, table 2. Then go back into the dimensional tables and look at dimension "G". Those numbers should be familiar.
Sorry for any confusion.
"Pumping accounts for 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
You must remember if it were not for some of these "dinosaurs" you would not exist!!!
Even I'm a young engineer, I've seen many mistakes and misunderstandings relating to class designations of fittings, valves, etc. As an example, few days ago I had a discussion with another engineer because he said: "valves don't have class, so doesn´t matter if we change a valve from class 150 to 300, it only applies to flanges"... After a while and many books and ASME standars open over the table, he finally understood that valves have class like fittings and flanges.
David.
