Immediate Settlement - Burland Burbridge
Hi, Im writing a spread sheet to calculate immediate settlement using the Burland and Burbridge formula.  However Ive come across a problem with the layer thickness correction factor, f1.  The equation is as follows:
f1 = H/z1.(2-H/z1)
The problem is that when H/z1 > 2, you get a negative number, which results in a negative settlement i.e. heave.
Can anyone please confirm if this formula is correct or not.
Cheers and best wishes for the New Year.
RE: Immediate Settlement - Burland Burbridge
Are you sure that the portion of the equation is not
(2-H)/z1  ?  Then the heave cndition does not exist.
Mike McCann
MMC Engineering
Sorry...don't know what I was thinking here as it still exists for H<2.
Mike McCann
MMC Engineering
I checked on the internet and found the equation - you have it correct.  The equation did have a limit of useage mentioned in the previous wording in that H must be less than Z, so for your condition, you cannot use this equation.
Mike McCann
MMC Engineering
Thanks Mike,
Can you give me the link that you used to find the BB equation.
Rob.
Unfortunately not, but if you google "Burland and Burbridge immediate settlement", you will get a few links to peruse.  The one I saw apparently was a textbook with all sorts of equations and test results.
Mike McCann
MMC Engineering
Myoho,
if you email me I'm going to send you what you need:
mccoy twothousandandfor twothousandandfor at yahoo dot com
No blanks, years in numbers rather than in letters
Myoho;
Have you considered "Peck & Bazaraa" "NAVFAC method" or "D'appolonia"  Just curious to know why Burland method?
In ASCE's geotechnical special publication No. 15, D'appolonia method was most accurate between predicted versus observed settlement study.
