Yield Line Vs, Strip method for RC slab analysis
Gretings!
Im interested if someone could give me some insight on these two methods and how they compare to each other.
Im aware of FEM power when analyzing slab structures but when a calculation by hand is required wich one of these methods would you use and why? Wich are pros and cons, and also how they compare to elastic methods like FEM?
Some book recomendations, articles...
Many thanx!
Many thanx!
RE: Yield Line Vs, Strip method for RC slab analysis
Usually strip method is being used for more regular and rectilinear kind of grids as the slab structutal layout.But, Yield Line method is used in more complex and rigorous layout with different boundary condiditions, such as triangular, circular, etc.
It is up to engineering judgment to predict the true failure mode of the plate which helps alot to setup a realistic set of calculations.
"Practical Yeild line Design" can help you alot to understand the philosophy behind this method:
http://www.concretecentre.com/PDF/PYLD240603a.pdf
cheers,
Sam
Strip method is a "lower bound" method meaning that you are ALWAYS conservative. That is, if you postulate a certain load path and your steel is sufficient to withstand those loads, the slab will not fail. Note: this does not have anything to do with deflections. So with the strip method, you may get a slab that is perfectly safe but way too flexible or that has way too many cracks.
I read what you guys said, also SamETABS I looked at the book before posting here.
Seem that Ill start with Strip method, couse that method will give you moment distribution across the slab wich you can use and arrange reinforcement details.
Also it gives you egsact amount of load thats transfered to the beams wich you can use for designing beams later on.
And it also an "lower-bound" solution!
If I understand corectly these are all plastic method of analyzing slabs, correct?
FEM is an elastic method, correct, wich looks at the slab when the first crack appear opposite to plastic methods wich look at the slab when complete collaps happens.
Did I get this right?
The strip method is more of a design method whereas the yield line method is more of an analysis method; i.e. pick a reinforcement pattern and find the collapse load.
I always thought that torsion basicly magnifies bending moments Mx and My in a plate member?! Is this statement correct?
Since the torsion moments are ignored in Strip and in Yield method, shouldnt both methods then be in the "upper bound" territory since theys will give you smaller bending moment values?
One thing more, I notice many FEM programs offer you to choose Poisson ratio number of concrete. Sincee FEM is elastic it should be 0.2.
But why not put it to 0 since it correspondes to the colapse moment?
Thank you
In a real slab the load is carried in bending Mx, My, and also in Torsion Mxy. If the torsion moment is "relaxed" and distributed to Mx and My these moments will increase. The strip method is a way of finding an acceptable pattern of Mx and My moments with Mxy set to zero. That's built into the method. The Mx and My pattern may not be the same as the pattern arising from an elastic analysis, nor might it be the most efficient, but it will be capable of carrying the applyed load. In practice the designer should aim for a pattern that is not too disimilar to the elastic moment distribution.
Does that help?
In our egsample, the formation of plastic hinges wich then turns structure to a mechanism.
If plastic methods are used for analyzing, one must be very carefull and ansure high ductility and rotational capacity of cross section wich is achived by limiting the neutral axsis depth.
Elastic methods look at the structure to the moment when the first cracks appear. In slab case there are bending moments and torsional moments wich have to be find.
From you answers theis is easiest achived by using FEM programs wich I also use.
But how to obtain valid results without using computer programs, when you dont have computer in front of you, and when you dont have those tables of coefficents wich you use to get bending moments in a plate?
I only see solution using strip method or yield line method, and these methods neglect torsional moments!
This might sound stupid, but is this dangerous?
These methods have been used for lot of years and the structures are stll in one piece?!
Is there maybe another way?
This is the reason the strip method can be used. If you look at the differential equation for plate bending, (crudely) it is something like this:
Mxx + Myy + Mxy = q
where q is the applied load. The equation essentially says your applied force has to be resisted by a combination of your internal moments.
If you set Mxy equal to zero, this means Mxx and Myy have to carry the difference, but the differential equation is still satisfied, and everything is in equilibrium. As a side note: If you wanted to treat this as a one-way slab (ie beam) you could set Myy and Mxy equal to zero and just design for Mxx. You would need a lot of steel for the Mxx moments, and the slab would crack significantly in the Y direction, but eventually everything would redistribute and be carried by the Mxx steel.
The only upside to designing for Mxy is to reduce cracking at the corners. When designing for Mxy you will be able to provide the proper amount of reinforcement at the corners to reduce torsional cracking. ACI 318 addresses this though by making the designer add a certain amount of corner reinforcement in the slab.
Is it the proper thing to do? No.
Is is a positive load path (provided enough reinforcement is sufficient)? Yes.
Will there be a lot of deflection/cracks? Yes.
Will it fail under the designed load? No.
This is the heart of yield line theory: as long as the designer provides a positive load path the structure will not fail. Thus, if you provided only Mxx reinforcement the slab will not fail.
Don't get me wrong I 100% disagree with only providing reinforcement in one direction for slab that is clearly two-way. I was merely trying to show an example.
my point is that if there's no secondary reinforcement it a stable one-way slab and will not fail.
NS4U is correct for a slab supported on fours sides. For a slab supported on columns you can't eliminate the moment in one direction by increasing reinforcement in the other.
To a degree you can redistribute the reinforcement in a slab supported on columns. After cracking, the moments will chase the reinforcement.
Torsional moments in a 2 way slab decrease bending moments in x and y direction!
Thats why the bending moments in x dirction for a simply suported slab are not ql2/16 and in y direction gl2/16. They are smaller,something around ql2/27 in one and in other direction.
What torsion moment do is to change direction of main bending moments, and because of that are not orthogonal like in x and y direction but are rather inclined and directed diagonaly to the slab.
Main moments also change sign convenion from positve to negative at corners if the uplift of the slab is prevented, so you have to provide "torsional" reinforcement at the corners
My=q*Ly^2/16
If the slab is simply supported on 4 sides and Lx=Ly.
I don't have access to my concrete code at the moment but I do remember a clause that talks about torsional moment and the corners and negative moment as the slab wants to lift at the corners. I will have to look further into it before I can comment.
You are correct, if it's on columns its a totally different ball game
My=q*Ly^2/16
If the slab is simply supported on 4 sides and Lx=Ly."
Is valid if the slab is not restarined against uplifting e.g. if there are no beams under the slab edges!
If there are beams under the slab edges, beams will have its torsional stifness wich will couse negative bending moments in the corners of the slab.
Uplifting is prvented, torsion is present in the slab, bending moments reduce in both direction, but negative momets appear at the corners where the torsion is at max.
I agree. The beams will go into torsion causing negative bending moment in the slab at the supports.
What are the dimensions of the edge beams and how have you calcuated the torsional stiffness.
...I think yield line method has offered an solution to negative moments at the corners (negative yield line), but dont know if elastic methods have somekind of formula for this...also dont know if strip method can calculate these moments due torsion.
Hokie66,Thanks for sorting out the NS4U's problem. I only just returned from a training trip plus holidays and have not been checking Engtips. You are definitely correct with flat slabs as distinct from 2way slabs (British definition Flat slab -slab system supported on columns 2way slab - slab system with continuous supports in 2 directions.).
RE Mxy moments, they cannot be ignored in design. They are not Torsion as is defined as compatibility torsion, they, combined with the Mxx and Myy moments on an element, are required to define moment condition on an element when using Orthoginal moments. If you design on principal moments, Mxy is zero but you cannot reinforce based on principal moments as their angle is different for every element. For design for flat slabs, Mxy must be combined with Mxx and Myy in the 2 design directions using Wood Ahmer or similar to get proper design moments. FEM design programs that ignore Mxy in design are definitely wrong and significantly unconservative.
I do not think that setting torsional constant to 0 or a low value is correct either. if you are going to do an FEM analysis you should do it, not fudge it into something meaningless, but then you need to design for all of the effects from it.
When Mxy moments are included, the design moments from FEM are the same as from strip analysis.
Elastic Analysis:
Strip methods should be used logically to model as close as possible to the actual elastic action of the slab, as should Yield Line if you want reasonable performance for crack control and deflections. Otherwise as stated by someone above, you will get large cracks and larger than expected deflections.
The same is true for FEM analysis and design. One problem with FEM is that some people are basivally doing a Yield Line reinforcing layout based on an FEM analysis (eg PT flat slabs based on banded/distributed average designs). This is not logical. You cannot base a Yield Line solution on an FEM analysis.
RE Deflections:
You can get very good estimates of long term deflections from strip analysis/design if you reinforce to the elastic moment pattern for the slab and allow for the transverse distributions of moments. Much better than most FEM programs give if you use RAPT to do it, but you have to understand what you are doing.
