Need schematics for electronic thermostat
I need schematics for small, simple, precise electronic thermostat for range 20- 80 gr. C, with Pt 100 or similar.
Can someone help me?
Thanks. Zlatkodo.
Thanks. Zlatkodo.
RE: Need schematics for electronic thermostat
http://home.howstuffworks.com/home-thermostat3.htm
htt
http://www.maxim-ic.com/appnotes.cfm/an_pk/3965
http://focus.ti.com/lit/an/slaa129b/slaa129b.pdf
http://www.national.com/apnotes/Thermostat.html
http://www.zilog.com/docs/appnotes/an0206.pdf
There are LOTS more app notes out there since a thermostat is well understood and makes a great example.
Good luck.
Engineering Incredible Solutions
www.incredilution.com
TTFN
Judging by zlatkodo earlier post, I think that he is years past homework. He may be speaking English as a second (or third or fourth) language. I don't think he is in an area where he can run down to a Home Hardware for an off the shelf thermostat. I suspect that he needs to build something that isn't available to him locally, even though it may be available to you or I.
Bill
"Why not the best?"
Jimmy Carter
TTFN
Precise thermostatic control requires much more understanding than "small, simple precise thermostat" describes.
Given that the OP still hasn't even described what the application is, how can anyone realistically answer the mail without knowing the complexity of the temperature control and plant part of "thermostat"?
TTFN
Thank you for your advice. I have already received the appropriate scheme.
Zlatkodo
