Osnap sensitivity
Osnap sensitivity
Is there any option in Acad 2007 to set priority of osnaps? I keep all my osnaps turned on, and when I have a lot of line intersected, for instance, and want to start a line from that intersection point, I come near to that point and my midpoint osnap is activated instead of intersection...Like that there is some sort of priorities in osnaps...Is it possible to set this somehow?
RE: Osnap sensitivity
use the TAB key to cycle through available object snaps.
There is no way to set a priority for osnaps.
Maybe you can toggle between osnap settings with a lisp, or using button macros.
Lothar
ADT 2004
