Plate thickness for Anchor chair (API-650)
API-650 limits the plate thickness of A36 to 40mm, what I wanted to know if this would also be applicable to anchor chair for the tank. Can i use more than 40mm A36 plate for the anchor chairs of a tank?
RE: Plate thickness for Anchor chair (API-650)
Joe Tank
You may also be able to change the style of the chair.
And consider using A516-70 or other available plate.
