Is there a way to make the def files of translators network based
Hi All,
We are using NX4. We have close to 200 machines which has NX installed.. We want to make these client machines pull the def files for trannslators from a server loaction..
Can this be done in NX4.. I know it can be done in NX6 ( via GTAC)..
Any help will be appreciated..
RE: Is there a way to make the def files of translators network based
Do you use DXFDWG_DIR,STEP203UG_DIR etc env settings?
It solve only deafult (initial) settings, but it is more than nothing :)
