Hydraulic Panel & Cathodic Protection sealine ???
There is a drawing of a substation in front of me for a liquid to gas plant.The plant is by the seaside and there are two equipment in the substation that I am clueless to what they are & I don't have any specs about them,I hoope you can help me out and guide me to some catlogs or data sheet abt them,they are the following:
1-Cathodic Protection sealine
2-Hydraulic Panel
I also hope you can tell me to what they are connected to in a substation.
Thanks!
2-Hydraulic Panel
Thanks!
RE: Hydraulic Panel & Cathodic Protection sealine ???
The cathodic protection panel will be associated with some buried structure, probably a pipeline or jetty considering the marine location. Any sign of something resembling either of them?
I think you have ask about cathodic protection in the Corrosion engineering
forum338: Corrosion engineering
Best Regards.
Slava
ScottyUK and Slavag reagarding the cathodic protection it is as you both said for the prevention of corrosion on the pipeline I guess the square drawing in the substation is a Cathodic Rectifier,and Slavag I will also ask regarding corrosion in the appropriate section.
As for the hydraulic panel it is basically for the pumps and the control of the valves
Thank you guys a lot for your time and reply,have a nice day!
