Centrifugal Fan in Boiler Application
While we design Centrifugal Fan as ID Fan for boiler flue gas,
...Assuming the Impeller to be Drum type Impeller (ie., Impeller Width is Constant).
A. Which type of blade should be used, ie., either BackWard Swept or Forward Swept or Radially Tipped.
B. What are the optimum inlet and exit blade angles.
C. Design procedures for Volute Casing for the blower.
Provide your valuable resources in ID Fan design for boiler.
with Thanks
LRamu
with Thanks
LRamu
RE: Centrifugal Fan in Boiler Application
