File inserted and file name also appers
When I insert a file into another one. I get the part I want along with the file name. See picture
RE: File inserted and file name also appers
OK, there are two things that you need to look at.  First go to...
Preferences -> Visualization -> Names/Borders
... and select 'Off' under 'Object Name Display'.
Also when you perform the...
File -> Import -> Part...
...operation see if the 'Create Named Group' option is toggled ON.
It would appear that you've created a 'Named Group' when you imported what I assume was the drawing border.  Also it would appear that you have the 'Object Name Display' option ON.
Anyway, check one or both of these to solve your mystery.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Thanks for the quick response.
It was Preferences -> Visualization -> Names/Borders
Thanks again
