Insert break on a cylindrical object
I am trying to create a break on a cylindrical part that will end up looking similar to the jpeg I have attached. I remember this being a standard thing when I was learning drafting techniques, however I am not sure if I can implement it in SW. Any suggestions?
RE: Insert break on a cylindrical object
Sketch your own.  Don't hold your breath waiting for SW to address this issue.  They only "fix" things that AutoCAD users find "nifty".
Dang, I really hoped this would be easier... sad
The Curve Cut option is the closest SW offers.
However, if you really want that "break" you can create a config in the model which has a cylindrical cut feature passing through the part at 45° ... but that's a lot of unnecessary work for something which should be so simple.
cheers
