Shrink around a radius
Does anyone have a method to apply shrink to a model along an arc.  Basically you can think of this as stretching the model around a radius of a specific size.  We used to be able to do this in Euclid years ago (stretch a part around a radius).
Thanks!
t.
RE: Shrink around a radius
What version are you running?
Maybe see if "local scale" (not just "scale") will help you.
I am not sure where it is located in the menu so I had to use HELP > COMMAND FINDER > "local scale"
to find it
Thanks Jerry.  I'll look at it.  I'm running NX6.
