Surface Rougness Cutoff Length
To determine a cutoff length for surface roughness measurement, the idea is to exclude waviness in the surface roughness measurement. But, how can in determine what cutoff length to use?
RE: Surface Rougness Cutoff Length
What type of instrument are you using for measurements?
Do you have control of the instrument to be able to control the travel over the surface, if so what are the increments of travel?
