keep on breaking spark plugs why?
I am working with a '90 Toyota tercel 1.5L sohc 4cyl.
and for reasons unknown to me, every month or so, the #1cyl
spark plug needs changing due to broken porcelin surrounding the electrode which in turn causes the #1cyl. to miss-fire. I undrestand that carbon build-up could eventually reach a spark plug with the piston at tdc; but I dont think that is the case since I have not been fighting any pining problems or dieseling.
The plug comes out displaying a color that looks good to me so I dont think it's burning lean iether.
RE: keep on breaking spark plugs why?
Mike Halloran
Pembroke Pines, FL, USA
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Does it screw in easy?
What torque?
Compression check?
Coolant loss?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I'm with Mike and Greg on this one.
Rod
I'm thinking it's the outside porcelain.
Rod
The OP says no detonation and good mixture or words to that effect, so that means the OP was wrong in his description or the damage is physical.
Physical damage in the chamber is the piston hitting the electrode which is not mentioned.
That leaves physical damage outside the chamber which all the respected long term members have already suggested with various emphasis on how and why.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers for professional engineers
Keep in mind that the "porcelain" is one piece and it is conceivable that a crack could be started from improper installation, I have not seen that except in one extreme case where the jerk used an impact wrench on a Ford taper seat.
You stated that "the plug comes out displaying a color---etc."???
How can you see a "normal" plug if there is enough detonation to "crack the porcelain"?
As you seem to already know, it's time for some basic diagnostics. Something is definitely NOT "normal"!
Rod
If the leads are the wrong way around on a 4 banger, it means that 2 cylinders are at least 180 deg out and the misfire will be obvious, and most likely spectacular with great flames erupting from the induction or exhaust and less than 50% power output if it runs at all.
The cylinder in doubt has higher compression, gets a higher charge density, has more advanced timing, has a built in glow plug or is running leaner than the rest.
The reasons for one or more of the above can be one or more from a large and varied list, from faulty ignition system to faulty fuel system to worn camshaft.
Pat
Pat
Would you suggest I change to a lower temp plug all accross the head? I should prob. pull the v.cover off and have a peek.
I wish I could convince the wife that it would be easyer to build a new sub-frame,shave the bottom of the passenger side shock tower and fab an adapter plate to mate a Supra twin-cam 6cyl to the stupid thing and call er' a day. hehehe
PS; thanks all y'all for your input.
Based on what you post here---I don't mean to pick on you, but do you know how to read a plug? Truly, most mechanics (even if they claim all sorts of book lernin') DO NOT!
Here is something 'just for those in the know'...My crew chief's wife burned up, for lack of oil, the bottom end of his MGB on the way back from Vegas..."But, the light never came on", says she! I can't post here what he said.
Rod
My brothers wife did something like that to two cars in a row
First was a VW Super Beetle with a 1918 cc forged piston bore kit, fully counter weighted crank, 40 DCN Webber big valves etc for 130 HP at rear wheels. It had an eternal oil filter and a big oil cooler up front fitted in line after the filter. On a cold start she popped the oil filter canister as it peaked out at over 200 psi oil pressure if reved before it had 10 or 15 seconds warm up time. She claimed that the oil pressure gauge read OK and the light did not come on as she drove it about 15 miles with no oil and drove it to a stall at full throttle in low gear on a level road. We saved inlet with carby, fuel pump, dissy, exhaust, generator, oil line, remote canister and some tinware.
Next car for her was more conservative (read idiot proof) It was a Holden Torana with a later model 3.3 litre straight 6 pushrod typical Chevy/Vauxhall inline 6 style engine. It had full CW crank and 12 port head with a 285 deg hydraulic cam and Rhodes lifters an 3 X 1.5" SUs. It Pulled good from 1000 pm in top gear all the way through to 6000 rpm where it ran out of power due to the small carbies. Once again gauges and lights. She burst a radiator hose. She claims the gauge was normal, the light never came on, no steam was visible (even though there were rusty water marks all over the windscreen) and she again drove it to a stall in low gear, WOT on a flat road. We saved the inlet with carbies, exhaust, alternator, distributor and flywheel oh and the fuel pump.
At that stage we considered a tank for her. Settled for a new SUV and replaced it every time the warranty was up.
We considered a system where a warning sound came into effect along with the idiot lights. The plan was for it to scream out real loud "HELP MURDER STOP RIGHT NOW ARRRRRRR"
Pat
For the subject Toyota, I have no specific knowledge of that model, but the #1 cylinder on most engines gets the coolest water and cylinder wear is typically worst there. It is possible that cylinder has built up a bunch of carbon, but is still burning relatively clean.
