PVC vs HDPE
PVC vs HDPE
We have designed a water distribution system to be PVC. The system supplies both domestic and fire service to 20+ warehouses. After the contract award the gov't PM and the contractor want to know if HDPE pipe may be used in stead.
Can the two be used interchangably? I've seen some literature where HDPE has be used to replace old DI lines. There is also some debate about whether the chemicals in water systems degrade the HDPE lines over time more quickly than PVC. I'm looking for information on installation procedures also. Can the two be placed at the same depth below vehicular loading and using the same bedding materials. What have your experiences been in the field?
RE: PVC vs HDPE
RE: PVC vs HDPE
RE: PVC vs HDPE
RE: PVC vs HDPE
RE: PVC vs HDPE
Corrugated pe can be buried with as little as 1-foot of cover (flexible pavement or gravel but not under rigid pavement) but your bedding material and compaction has to be A-1, otherwise you're toast. Remember, before fiinal grading you won't even have that 1-ft of cover.
I flunked chemistry twice (okay, it was O.Chem.) before I passed it but I would investigate the particular water chemistry in the supply system and check compatibility for PE and PVC on checmical resistance charts.
RE: PVC vs HDPE
There are several things to take into account with HDPE pipe:
Make sure you look at the sizing of the pipe as the HDPE has a thicker wall; therefore, you might need to upsize the pipe to obtain the same interior diameter.
You also need to spell out what SDR class you want as various SDR classes have various pressure ratings as well.
Also the coefficient of thermal expansion is different than other materials and depending on the method of installation(ie boring, opencut,etc.), restraints may be needed at the connections to prevent the pipe from pulling away from the connections.
You are doing right by investigating the differences.
A search on HDPE waterline will yield you plenty of info. Another good source of info is AWWA's publication "PE Pipe - Design and Installation".
RE: PVC vs HDPE
RE: PVC vs HDPE
Richard A. Cornelius, P.E.
WWW.amlinereast.com
