replace a 3p motor in a old builidng which no grounding
Hi, I was asked to replace a new 3phase 208 Voltage,10hp motor to a old one. But unfortunatly, the old feeder to control panel no grouding,so how can I grunding?, befor the old motor no grunding still worked long time,Can I igord the grunding in this situation? Thank so much for reply.
RE: replace a 3p motor in a old builidng which no grounding
Thanks so much for reply. Yes, the feeder is metallic conduit,but I want to know whether the inspector will approal or not as per the code if we assume the feeder conduit will serve as a grounding. Since We installed a lot new feeder with EMT,it is metallic, but we still need a grounding wire inside the EMT.
If the motor is near a mass of metal that is grounded I would consider bonding the motor frame to that also.
Roy
Per section 250.118 of the NEC, both rigid and EMT conduit can be used as an acceptable means of and EGC as dpc mentioned above.
I would think that with these being listed as acceptable means in the NEC, that inspector would have no problem approving them.
EMT may be used, Rule 10-804, (d) subject to some exceptions.
Watch your connection to the motor. Flex is not acceptable for grounding. You may not transition directly to flex unless there is a grounding conductor oin the EMT
You may, however, use a junction box or condulet to transition from EMT to flex and run a grounding conductor in the flex from the motor to the box or condulet.
Rule 10-618 (3)
If this building is over 50 years old, and the EMT is coupled and connected by "indent" fittings, they may not be acceptable for grounding.
Bill
"Why not the best?"
Jimmy Carter
If it is broken, fix it. If it isn't broken, I'll soon fix that.
Bill
"Why not the best?"
Jimmy Carter
In this old building,I just did exactly as Waross advised; wired a ground inside the flex from motor to the box/control panel.
