Assembly Navigator Order?
Is there a way to set the assembly navigator in NX5 to show the order in which components were added to an assembly. A search of this forum turnd up nothing.
Other than using mating conditions, how can I tell what is constrained to what?
Thanks...
Thanks...
Fighter Pilot
Manufacturing Engineer
RE: Assembly Navigator Order?
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
You can even have links between parts that do NOT exist together in an assembly. The assembly does not update in a structured order. Assemblies are not top level files, with components below them, the structure of an NX model is more peer-to-peer.
NX 5.0.3.2 MoldWizard
Yes, many years on Pro/E as user and administrator. Sometimes I want to insert a component ahead of another and then reroute/redefine my assy references around. Finding it hard to break the Pro/E techniques when using UG.
Fighter Pilot
John R. Baker, P.E.
NX Design
Cypress, CA
Not really. I wouldn't keep asking questions if I did.
Example from today. Yesterday I had a screw I assembled into a hole (mate surface, align axis). Today I needed a washer under that screw. My Pro/E thinking was if I could insert components ahead of the screw that would supress the screws off automatically. Then I assemble the washers (mate surface, align axis). Now I resume the screws and then go in and reroute the mate reference of the screw from the part to the washer. Everything readjusts itself.
I see in UG however that I can violate hierarchy rules by supressing the washer and the screw remains without complaining about the parent being supressed. I suppose this is OK, I'll have to try it out. I've used that sort of hierarchy in the past to quickly automate assemblies and create families of a design. If I have a plate and I supress it in one assy of a family but not in another, I'd like to fasteners to go away automatically. That to me represents reality.
Fighter Pilot
John R. Baker, P.E.
NX Design
Cypress, CA
I'm using Assemblies/Components/Add Component to select the components to add. Then there is a dialog that says Mating Conditions. I'm using Mate, Align, etc from that menu.
This is strange. According to the documentation, Assemblies/Components/Assembly Constraints should be in the menus. I don't have that. Then there should be Assemblies/Convert Mating Conditions. I don't have that either. WTF!!!!!!!!! Argh!!!!!!!!!!!! I'm on NX 5.0.3.2 and the Assemblies application is on.
More arghh!!! Now I see it. Preferences/Assemblies dialog and then pick Interaction/Positioning Constraints to activate.
Lemme work with this, there may be more questions in the future.
Thanks...
Fighter Pilot
HTH
Joe
Rediculous perhaps, but it works for the type of assemblies I make. Mating conditions and wave links become terribly complicated when used together.
With proe, your assembly navigator and part navigator is all one tree. Assembly regeneration starts at the top of the tree and runs through to the bottom. UG does not support assemblies in the proe sense, UG is a collection of isolated components. All components are based around the absolute csys if not mated.
As a component updates, each reference to another component (incl. mating constraints and wave links) will cause that component to update. There is somehow more to it than that since when I make multiple changes, I dont see components updating more than once, but I havent got the faintest idea how it works. I've been at it for a year and asked some intellegent people, but there seems to be no knowledge of how UG updates work. This "black magic" led me to NOT mate components, unless I can mate them only to fixed datums.
John R. Baker, P.E.
NX Design
Cypress, CA
