Can Natural Gas pressure be boosted using pumps
I am waorking on a building services project in Australia with natural gas service pressure of 2.75kPa being supplied by the retailer. The builder has now proposed that instead of 2.75kPa boiler, he wants to install 4.0kPa heating water boiler (says the selection had a typo when submitted for approval). Can someone advice whether it is possible to boost the line gas pressure using a pump (boosting the authority line pressure is not feasible as inlet mainfolds & piping are already installed)?
Thanks, any advice is appreciated.
RE: Can Natural Gas pressure be boosted using pumps
Yes, but they usually call them compressors,
Maybe this kinda' thing is what you're looking for,
www.compair.com/dl.asp?section=lit&file=V04g-V18g_vane_gas_datasheet.pdf
although this one might be a little too big, smaller capacity machines must be around somewhere.
"Pumping systems account for nearly 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic  (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
