UG-14 and flange
UG-14 and flange
Hi all,
I do know that bar and rod material may be used for manufacture of shells and heads of pressure vessels using code cases 2155 and 2156. Could anyone perhaps point me to a code case and/or interpretation for use of bar stock for the manufacture of flanges for pressure vessels? It seems UG-14 prohibits this.
Any help would be highly appreciated.
Thanks in advance!
Thanks in advance!
RE: UG-14 and flange
Thanks for your response CodeJackle!
Also see the following interpretation which I think does not help your case:
Interpretation: VIII-1-07-17
Subject: Section VIII, Division 1 (1998 Edition, 2000 Addenda); Appendix 2, 2-2(d)(1)
Date Issued: January 8, 2007
found here:
http://c
Interpretation: VIII-1-86-171
Subject: Section VIII, Division 1, Appendix 2, 2-2(d)(1), Use of Bar for Manufacture of Hubbed Flanges
Date Issued: October 26, 1987
Please consult your AI or AIA of record for clarification of Code requirements.
In the meanwhile if you could think of something else, please do keep the suggestions coming in.
I will keep you posted.
Thanks again.
I am not offering an opinion on the use of bar, though.
Mike
Any new thoughts in light of this info?
Your flange can be designed as an integral flange similar to Fig 2-4 (5).
UG-14 would appear to disallow bar for this use, however we recently bought some approx 10" round that was certified as both bar and forging, you might look into this.
I don't know if there are any applicable Code Cases or interpretations, sorry.
Mike
See unofficial link:
http://cstools.asme.org/csconnect/pdf/R6576.pdf
I also agree with SnTMan's comments regarding integral flanges.
Hope the material i have gathered with your help serves to a allay the concerns of out NB.
SA-479 is a bar specification and the limitations are specified in UG-6(b), UG-14, and Appendix 2.
NOTE: Appendix 2 paragraph 2-2(a) specifies compliance to UG-4 through UG-14.
From prior posts I know you are aware of the Code Cases CC-2155 and CC-2156-1
I believe the same limitations for the use of bar materials exist for the use of plate materials.
See UW-13(f) and Appendix 20 for limitations on the use of plate.
Why, because it is written in the Code that way. I am sure the ASME committee members have their reasons, maybe not the same reasons, but as a committee, they agree on the limitations.
