ARE THERE "UNDO" AND "REDO" FUNCTIO
ARE THERE "UNDO" AND "REDO" FUNCTIONS IN DRAWING MODE
(PRO/E 2001)
RE: ARE THERE "UNDO" AND "REDO" FUNCTIO
no. its there only in the sketcher mode
how about deleting the feature and later realising of the need for it "Is there an UNDO for that"???? that's what Mr.dan14 asked I guess.
Am I right ????
regards
thilak
In a way there is a REDO, by using the Trail Files to repeat your design steps. First you must know where to find the trail files (usually in the Drive/ptc/bin or working directory), and then edit the file to show only the features that you wish to recreate.
Steve
http://www.3dlogix.com
u r right Steve. we can have the trail file set to a folder through config file and can be run whenever needed can be edited using notepad and saved). but for big models its not a success always. (maybe 70%)
thilak.
regards
thilak
Thank for Everybody!
But I ask about Redo and Undo in Sketcher inside
Drawing Mode.
